Fairphone after Updating to Android 11 unstable - WiFi unsuable, constant rebooting device
Hi there, after updating to Android 11 our two Fairphones are really badly injured. WiFi is unstable and reconnects frequently. But the worst: three times a day a rebooting device.
Is there any solution to this?
Cheers,
Christian
That I have more so on 5GHz, so I switched to 2.4GHz; but no rebooting.
So do you have an SD card installed an how is it formatted?
I use a Fritzbox! and there a few reports of it being a bit iffy.
have you tried a ‘safe mode’ start which disables your custom apps, in case one of those is interfering?
Ok that’s a start :thinking:
Oh! is the Wi-Fi for calls or data. You can try Wi-Fi without a SIM card and see if it still reboots.
You can enable aeroplane mode to disable all then enable only Wi-Fi
