Fairphone 6 /e/OS freezing
My Fairphone 6 with /e/OS gets frozen from time to time with no apparent reason. It usually happens when the screen is off or just on the lockscreen, so not even while I’m doing anything. I guess it’s caused by something running on the background but I’m not able to find what it is.
When it happens, the only solution I found is completely rebooting the phone by pressing all 3 buttons for like 20 seconds or so, which becomes quite challenging when the screen is off, as it’s difficult to know when to stop pressing and if I press it for too long it freezes again.
Anyone having the same problem? Any possible solutions or advuce to identify what is freezing the phone?
Thank you!
If it happens often enough you might consider to enable USB debugging and connect a computer via USB where you could use adb -d logcat to monitor the output.
When phone freezes you might find some enlighting output there.
