Fairphone 5 with e/os any issues with phone signal in the UK/Ireland?
Hi All, I put e/os on a samsung galaxy a72 for a friend a while back, but they then ran into a tonne of SIM connection issues in the UK and Ireland. I’ve been using the fairphone 5 for a while and haven’t had any issues but I don’t use my sim much and especially don’t make many phone calls.
Therefore I’d like to check, UK/Irish/wherever fairphone 5 customers who are running e/os have you had any issues with SIM connectivity?
I have a fairphone 5 from Murena with /e/OS installed and an eSim and though I get few calls i have no problems here in England with my mobile provider Honest that are powered by Three UK
I am using a Fairphone 5 with /e/OS installed (not Murena, did it myself) and two SIM cards active: 48.ie (using Three network) as physical card with 5G enabled, LIDL Connect (Germany, using Vodafone) as eSIM without data enabled.
Both SIM cards are working fine, no problems at all. I am living in Ireland in Dublin.
I regularly travel from the Republic of Ireland to Northern Ireland (UK) and back, no problems here as well in general. I had to manually set the APN for mobile data once after crossing the border to NI for the first time having that setup, but since then, all good.
Hope that helps!
I have exact same set up. eeee (excited) .
