Was wondering if the SD card reader has support for uhs 2 micro SD cards with a second row of pins?
No it does not. It is a regular UHS 1 reader.
I know the FP5 can take upto 2TB size Micro SD CARD (room for one).
Wouldn’t UHSII be backward compatible with UHSI
I couldn’t see that written in Wikipedia, they did say UHSIII is backward compatible to UHS II. So assume the same but at lower speed then its card capability.
Yes! As far as I know, UHSII and SDEX cards can both fall back to USHI speeds for backwards compatibility.
