For about three weeks or so, the network has been disappearing. This means no calls, texts or data (though wifi work’s fine). Once I notice, a reboot fixes it and the network (in my case Giffgaff) is back. I can have several losses in an hour or none for several hours. I have not noticed anything that may link the times where the network has disappeared.
I don’t see anything similar when I search the forum. Is it a known issue? Any suggestions? Thanks.
You can try to convert your physical SIM to an eSIM through the giffgaff app (it’s a quick process) OR ask giffgaff to send you a new SIM, as this sounds like a classical SIM issue.
Another potential quick fix is to GENTLY (with a soft cloth, can be a shirt if no alternatives are readily available) rub the contacts of the SIM card and reinsert it.
Thanks for the suggestion. Getting a new SIM a couple of days ago, as someone else suggested, seems to have worked. So, it looks like it probably is/was a faulty SIM issue. I’ll give it a few more days before marking it as a solution. Plus, I’d be reluctant to go without 5G, so hoping to avoid that.
