Fairphone 4 doesnt connect to my PC, Which drivers do I need?
Hi, when I connect my Fairphone4 via USB Cable it doesn’t show up.
I tried several cables & the phone is in data transfer mode. It works on another pc & other android phones work connect to my PC. Does anyone know which drivers I need for the fairphone4?
Solved: Go to device manager, uninstall the device & reconnect. Make sure you dont have any other adb drivers installed.
