I am in Albania with a fairphone 3. I got a Vodafone Albania Sim card and removed my usual Sim. I then tried the new SIM in either slot but I am not getting any data connection. Any help is appreciated!
Thanks, Martin
Thanks, Martin
Did you check the APN settings?
Yes. The guy in the shop did the APN settings and he also did not understand why it doesn’t work. I looked up the APN settings myself and they seem right.
So it works now but I don’t understand why.
I put back my usual Sim in slot 1 and the Albanian one in slot 2 and it works. Mobile data only activated on the Albanian one.
