A long time ago my system upgrade failed. I was trying to follow the article FP3(+). Install Fairphone OS offline, but the script does not seem to have any hope of working.
In particular, when I extract the archive, the linux-x86 folder is completely empty. Therefore running
sudo ./FP3_flashall
sh: 1: ./linux-x86/fastboot: not found
there is a fastboot in the macos directory, but it is malformed and won’t run, even if I move it to the linux directory. Does anybody know where I can get a script/archive version that will actually work?
I have filed a bug report about this with the Fairphone support not too long ago.
Not sure if they are going to fix the current package but I assume the next update will bring a working install ZIP again. There is no announced date yet but there might be a November update.
