Fairphone 3+ Extremely Slow
Hi there,
I’ve had my Fairphone 3+ now for just over 4 years, but the last few months it’s been incredibly slow to respond and laggy. I will often get “this app is not responding messages” that don’t go away even when the app does start to respond again.
I have factory resetted it a couple of times in the last few months and it doesn’t seem to help. My storage level is good at only about 60%. I am up to date with all updates.
One interesting thing that I wonder if it is related is that every time I switch off and on my phone I will get a notification saying Quickstep is not responding and I have to close the app. I hear this app is used in the background to open apps? Not sure if there is another app I can use for this, or fix the original, but I can’t seem to find the app anyway.
Is it just time to get a new phone? I’m not sure if “designed to last 7 years” means it still works but works very badly, but quite disappointing. It has always been a little slow to respond, but this is now getting pretty unusable.
Any ideas much appreciated.
Benji
Hi
Quickstep is a launcher, you could try a different launcher and see if that helped.
You can search forum for suggestions of alternative launchers, for example
I am currently using Pear and it helped with some of my issues. Yet I need to say I advised it to someone on Reddit and it apparently didn’t work as intended.
Btw have you noticed any, even temporary, improvement after the factory reset?
Perhaps an app is slowing down the phone.
If you up to it, start your phone in Safe mode and try who it behaves then.
Just my personal anecdotical evidence: I am using /e/OS on my own FP3+ for four years now (by now on Android 15) and compared with another FP3 that ran on Android OS (formerly called Fairphone OS) Android 13, the FP3+ runs smoother and snappier. This might be the case with other Custom ROMs as well, however Android OS will certainly provide the highest possible compatility with apps.
So I factory reset my phone when I posted on 23rd Oct. I’ve now just had the last couple of days where it has got a bit laggy and apps have come up saying they are not responding. So it is a gradual degradation after the reset that seems to get worse quite quickly.
I have just tried installing the Pear launcher, thanks for the recommendation. I will see how that goes in the next few weeks.
Same issue here. Disabling all batterysavings options helped a lot.
May I ask you which and where?
Which OS do you use?
Stock os, I found the settings under:
Settings → Battery → Energy Saving (I’m not sure about this one, my menu is in Italian)
In this last page you can disable all energy savings options
