Hi there !
My first post on this forum, after about 1 year of satisfying usage of my Fairphone 2. A little thing, although : FP 2 is not compatible with DJI Fly app, which is necessary to fly DJI Mavic Mini and latest DJI Mavic Air 2.
So i was wondering if Fairphone 3 was compatible with this DJI Fly app ? Has anyone tested successfully the installation ? Is someone here able to test the installation (no need to have a drone for this…) for me before I buy one ?
Official DJI webpage https://www.dji.com/fr/dji-fly?from=dap_unique&pbc=f-u9-13H&pm=custom#download make it possible to download via Play Store OR downloading directly the APK.
Can someone help me please ?
Thanks a lot !
Rolland
Hi! (and welcome )
I just downloaded the app on my Fairphone 3 (via Google Play) and used it for a while without any problem or error (but I couldn’t connect it to the drone, as I don’t have one).
I’ve attached some screenshots I’ve taken using the app, so you can check how it looks in FP3 .
Open this to watch the pictures 👇
I hope it helps!
Hi ! Thank you for your help. Yes indeed that helps a lot !
I can now begin to resell my FP 2 in order to buy his new brother FP 3 !
Have a nice day !
-------- Message d’origine --------
On 14 juin 2020 à 23:49, Miguel via Fairphone Community Forum < noreply@fairphone.com > a écrit :
I have a Fairphone 3 and a mavic air 2.
You can start the app and connect it to the drone but once I started the camera the App stalls and does so even after reinstallation.
To be precise:
You can connect the drone, choose the settings and I could actually make a photo.
But when I started the camera for a video the app crashed. This was reproducible. On the mavic I could see that there had been video files created and the Mavic obviously recorded until I shut it down. So the app could not restart while the drone was recording.
I did not try to fly the drone not sure what happens when the app crashes while flying.
Very interested to know how this works out for you Rolland. I just bought a DJI Mavic Mini only to discover my current phone doesn’t support it. I’d love to go with a FP3 but based on magellan2k’s reply I might have to hold off until I can verify that it works.
I will be waiting with interest to see how yours works out with all the features
Unfortunately the FP3 does not fit the bill to control a DJI drone; you can run DJI Fly app, but it will crash reproducibly under particular conditions. I had to buy another phone just for the purpose to work as my flight controller.
Because of course - I stick to my FP3 for everyday usage
Thanks for the info. That’s disappointing. Do you mind me asking what phone you bought for the controller?
Since my current phone works fine, I don’t particularly want to spent a lot of money on a phone that just acts as a controller. I will have to wait to buy FP3 when the current one no longer works
The phones on the compatibility list provided by DJI are a safe bet. I got a used Huawei P20pro - works fine
That’s great, thanks. I’ll see if I can dig up a compatible phone from somewhere.
I wonder if anyone has used the Litchi App on FP3 …
It’s €25 but you can get a refund if it’s not compatible. I tried it there on my current phone. It launches fine but doesn’t connect. Possibly too old. Worth trying on FP3 and getting a refund if it doesn’t work. Support for the Mavic Mini has begun trials over the past few days so it should work on that app soon
Anyone successfully connected and flown with the FP3 and Dji fly or GO4 app yet?
Still no one successfully flown a DJI drone with the FP3?
I have a DJI Mini 2 and am doing permaculture surveying with it using DJI Fly and a FP3+ without any problems. Except the phone reboot that seems to happen regularly when I am on the border between WiFi and 4G, anyway!
(If I turn off WiFi and just use mobile data, the phone is stable - the challenge is remembering to do that before the drone is at 50 metres and beginning its work 🤦)
I tried out a Mavic Air 2 yesterday with LOS 16 on my FP3 using the DJI GoFly app and it worked like a charme in case anyone wondered.
I’ve waited quite a lot to see the evolution and updates of the DJI Fly app, and get the money for Fairphone 3.
Your answers show that DJI Fly app can apparently run fine on some FP3 (for @pratched and ibl) but not on others (for @magellan2k, maybe the app has made some improvments with all recent updates ?). I’ll give it a try and order a Fairphone 3 (or FP3+, still wondering…) and a DJI Mini 2. If everything is fine, that’s cool. If it doesn’t work, I’ll go and buy a used compatible smartphone, dedicated for the drone.
Thanks a lot for your feedbacks.
I’ll try to get you fresh news as soon as I’ll have all the stuff ready
Hi there. I’ve had a DJI PFV since 2021 and a Fairphone 3 since late 2020. Downloaded the DJI Fly app (probably through the google play store) after getting drone and it worked absolutely perfectly for months. Due to various reasons I didn’t use the drone for a while at the end of the year and deleted the app in order to save space on my phone. Soon I’m leaving on a trip and really would like to bring the drone, so I wanted to reinstall the app today, downloaded the .apk from DJI Fly - Download Center - DJI but it won’t work. I changed permissions settings and it said it was installing the .apk but then I get a message saying: ‘app not installed’. Do you what can be the solution? I would really like to use my drone and take pictures and videos and all that wonderful stuff. Thank you.
Is the App not available in the Play store? If you use another ROM without Google you can still install via Aurora Store which you can find in the F-Droid Store
the actual app 1.6 is from 2022 June, 15th
maybe this one is no longor compatible with your FP4 and you had an older app version installed from gugel play store.
what’s happen with the one from playstore? is this one working?
otherwise you have the problem like all the other users here before you upwards in thread…
