Fairphone 3 (after upgrade to android 10) starting after unlock
Hallo together,
I’m very lucky with my fairphone 3. But after the upgrade to android 10, sometimes the phone is restarting after unlocking it. Then the phone is telling “Smartphone is starting…” and it took a while…
The phone is on, it’s only locked… I unlock it… and then the message appears…
Any ideas whats happen? I’m not sure, what and when it happens…
I tried to call the phone after night… it works fine… But sometimes it’s not only starting… sometimes it boots again…
How can I downgrade?
Thanks in advance…
Vegisto
I think you should first consider a dic:factorydatareset, sometimes it helps.
Else…
Bear in mind that both procedures will delete all your personal data.
Hallo,
with 3.A.0077 it works.
Thanks
Vegisto
