Hello, brand new member here. I got a secondhand Fairphone 2 about six weeks ago. All was ok until the battery started getting really hot. Then it wouldn’t charge. I bought a new battery but that too is not charging (the red light comes on but just stays on and nothing else happens.)
Thanks! I’ve tried several different cables (and they work with other devices). I also tried cleaning out the “port” where the charger goes in. No joy.
Have you taken out the battery? And the black rim (the smaller part of the case)? Other than that, the first removal of the display module is always hard.
Ah ok! Well, usually it should show an animation of the FP2’s interior (with the battery graphic showing charging), but unfortunately yours doesn’t. I’m starting to wonder if there’s something wrong with the display.
If you can keep checking if the battery runs hot from time to time, you could try if the red LED ever turns green (but this could take an hour or more likely two or longer).
I have a similar issue. Except for a FP2.
A heavier drop (popped some plastic off) is the only recent misuse that I can recall.
I tried several Charger/Cable combination.
I also went trough a manual OS-Install several times.
In between I dismantled the whole phone and cleaned all the contacts.
The behavior stays the same.
No charging. Except for some initial “juice” until the Blue Battery Shows up.
This is the part that bothers me the most.
So, I dug up a cheap USB-Voltage display and observed, that approximately 1.5A is used during the “red led blinking”-phase.
I guess, until enough power is charged to run the “blue-battery” display.
I noticed that the battery got a little bit warm, when I re-installed the OS.
What I came up with, was to drain the battery until it would boot into “red led blinking”.
Then I would hold volume_down and power, and plug in the charger.
This takes about a minute, but this way I can enter the fastboot mode, and there is a 1.5A usage on my power-monitor-dongle, while the phone is getting warm and the LED is blue.
This is the state right now, and I will wait for about 2hours, to get a fully charged battery.
In the previous run, where I had enough juice to fully boot into the wiped OS for a couple of minutes. Everything seemed to be working fine. No inserted SIM/Sdcard, but Sound, Camera, wifi … all good.
But it did not recognize the available Power at the USB port and started charging.
I am really curious what the Issue might be. I had this device for about 6 years now and already changed the port-module and the battery about two years ago. Back then the USB-port was clearly wiggled out and the whole thing was a minor cost.
Okay. I had the new Bottom Module for 23 Months now.
Order Date was September 26, 2019.
They are “permanently out of stock”.
If I can’t repair the charging Issue, and quick part replacement is not possible, I might have to buy the latest iteration.
Maybe this 2016 Device ends up as a fancy TV-Remote when those fp2-new-usb-c-bottom-modules become available sometime.
You should have 1/month of warranty for the bottom module, so please contact support and see if they feel they can replace. For those cases FP kept modules on stock.
The USB c module is not officially sold by FP and I assume it will never
