My Fairphone 2 just has a RED status light.
Removed and installed all internal parts.
Removed SIM, Battery and SD card - attached power.
Tried multipule cables and chargers.
Left battery out the phone for >30 mins
Checked USB port for fluff and pocket debris
I’m just getting a red status light as soon as power is applied, not responing to buttons.
The latter would suggest an all dried out battery (0% – bad for the battery health). In that case, the usual procedure would be to just let it charge until the LED eventually turns greed (and not switch the device on before).
Did you try removing the battery and plugging the phone? This should start a pattern vibation-logo-LED cycling. If not, you probably have a hardware problem, possibly with the core-module.
Currently, the only similar case where I get this is a bricked FP2… Doesn’t mean it’s the same for you though, but if this pattern doesn’t show it does indicate some sort of hardware fault, if you’re lucky only with the USB-port (unfortunately, I think it’s rather rare) or if you’re unlucky, with the core-module, or a deep software/firmware problem.
The same happened to my FP2 two years ago, it just didn’t start, without the battery I’d get a solid red light switching off after a dozen seconds, due to a factory defect of the motherboard I had just started noticing.
A little hope perhaps, what is the output of the command lsusb when plugging the phone to a computer with the battery (on linux, similar on windows would be connected devices)? And the same when you unplug the phone (to see a difference)?
