On 5 July last I bought the head module at the official online shop.
The video smartphone confirmed that the replacement was successful.
After replacement the area of the module head began to have a strong heat that is not finished except off the smartphone.
I tried turning on my smartphone again but the problem remains.
I ask help to the forum mainly if others have had same problem and then how they solved.
Thanks in advance.
Perhaps try opening the phone, taking the module away, cleaning the contacts then putting it back.
Otherwise, perhaps you could contact a #fairphoneangel to see if the issue comes from the spare part.
Last but not least, #contactsupport. If the spare part has a problem, you should get it replaced under warranty.
If Alex’s suggestion doesn’t help, I’d reconsider if it’s really the top module that is heating up – or actually the FP2’s Snapdragon chip that is right below it. See Step 13 here (chip squared in red in the photo):
