Front-Camera dark and upside down after update to Android 9
I guess you are talking about the official Android 9 update 21.03.0-rel2 of the FP2? Are you using FPOS or FPOOS?
In which App do you encounter the problem?
Hallo, yes Android 9 update 21.03.0-rel2. The problem encounters in the standard-foto-App Version 2.0.002 (front camera dark and upside down, back camera ok) I´m sorry, I don´t even know what FPOS or FPOOS means.
The issue is known and being worked on.
Short term workaround: install another camera app (e.g. Open Camera).
Long term solution: if everything goes according to plan, we might have a fix by the next maintenance release.
FPOS: Fairphone OS (regular operating system with google apps and services)
FPOOS: Fairphone Open OS (same operating system but without google)
Edit: Slight modification
I can confirm it now, just tested it with my FP2 which got the update yesterday, when I came home.
