Dear Fairphoners,
I have just manually updated my fairphone with the new Koala 1.7.8 and also wanted to update the storage partition in tha same manner (I had an old partitioned FP1) afterwards.
After the installation of the storage partition (it was installed and I "wipe charge"ed it with a subsequent reboot) the reboot only mounted until the blue screen and it is stuck ever since.
I can not enter the recovery mode anymore, when I press volume up and the power button for a 10s, the screen briefly gets black and goes back to blue after. So there is no “no command” screen. The same happens after I take out the battery and try to get into recovery mode, also there is no typical “switch on-vibration”. Again, it only turns black for two seconds and then blue again–> no reset possible
Help anyone?
Thanks a lot
Also, I have done a complete backup of my files before.
