Fairbuds staying in ears
A trivial issue, but I wondered if there are any tips about placing the fairbuds in the ears. Mine don’t quite fit well. I have tried all the provided rubber ends - small, medium and large, but it does not work. Of course, when I keep needing to fit them in, it pauses or interferes with the sound. I think it is a common problem with these type of devices, as I have had the issue with a previous brand.
I’m having the same issue… I wish I had something to recommend you that works… I tried silicone “universal” wings that didn’t fit the earbuds. I hate suggesting buying more things that might not fit as a solution but there are tips of in-between sizes that might work for you or there’s earbud attachments like those wings meant to help hold them in but none of those are designed for the Fairbuds and even the “universal” ones I had didn’t fit… if there’s a more popular earbud brand that’s similar size and shape maybe getting their attachments would work… probably don’t want to give them my money though.
the rubber tips coming with the buds are hot garbage. too soft to provide stability, and they block very little outside noise.
get some 3rd paty tips. (you don´t need “wings” if the tips are good). i use “inAirs air1” foam tips and they are a 100 times better. they keep the buds in the ear and they block outside noise. if you do not like foam tips, there are so many other alternatives out there, and most of them will be better than the tips that came with the fairbuds.
PS: since the tips mostly are flexible, they will fit on the oval shaped buds just fine.
dont make it not fit? you mean, which do not fit into the case?
well, the inairs air1 size “M” do fit just fine. the rest you´ll probably have to figure out for yourself, because I don´t have all brands and sizes here for testing.
