My FP2 has suddenly stopped accepting charge. I have tried 3 different cables, all of which have previously worked, but none do. I think it is a problem with the USB port in the phone itself. Any ideas as to what I can do about it?
Thanks! Jude
You could see whether you can carefully clean dirt out of the port with a slim tool like a needle or similar.
If you happen to have Fairphone Angels in your vicinity (see #angelsmap), you could ask whether they would be able to help with troubleshooting by e.g. swapping the bottom module temporarily.
If you need a workaround to charge the battery, there are universal smartphone battery chargers around which can charge your battery outside of the phone.
Those are really helpful suggestions. Thank you! I will try them all!
Jude
