External universal chargers for Fairphone batteries
I bought one of these and tried it out for the fairphone 5 battery. It seems to work okay. Charges to 85% like you said. It’s a max of 0.5A so it’s not that much current (you have to switch it to that since there is also 0.1A option). It takes around 10 hours to charge. Apparently Adafruit also sells a 1A version but haven’t tried it, and it has a different usb connector.
It’s hard to get the wires in there, you have to adjust the battery on table carefully so the end of battery kinda falls on the wires to make contact.
Update on this. I found the actual fp5 battery connector on aliexpress. They are all the same so you can shop around for a good deal, except it has to be the 7 pin 2mm one, not 2.5mm. https://www.aliexpress.us/item/3256807309500432.html
It’s called a male battery blade connector 7 pin 2mm pitch. It snaps into place for the fairphone 5 and it maintains connection. (The male connector goes into the female battery port.) I soldered the wires from the adafruit charger to the male connector and it works perfectly to plug into the fp5 battery
Or via the internet from a number of vendors in China. Here are e.g. Google picture search results for this picture of it
s-l960
Or for this one
s-l960
(Just because I finally got curious why this particular charger didn’t readily show up in force online when searching for its supposed brand + name.
While I had good experiences so far with a different type of cheap-o charger, just looking at the prices online I would make sure to have a fire extinguisher around, too, when using this :fire_extinguisher:.)
For users not reading or remembering the post above which I cited … words of caution:
My charging for FF5 does not work reliably (switching the usb module didnt help) and i am still waiting for support to answer, so I am migrating and in order to do that I need a full battery, so I am looking how to charge it. And wasnt too happy with aliexpress so I am looking for a more local (austria/europe) supplier:
It seems in german its called ‘Stiftleiste mit 2mm Raster’
Buchsenleiste could also work in some settings.
Found something here Stiftleisten zB abgewinkelt, einreihig, Raster 2mm
Hi, do you just need a fully charged battery for a few hours? Perhaps a local FP angel could help with that?
Hopefully you will get it all sorted with FP5 soon.
I found out my angel is on holidays, so I went for soldering a 2.5mm blade connector i had lying around to a “universal” charger, which was too slim for the FF5 battery. It looks awful, but it works.
Thanks for the wishes and the idea, appreciated
Little (or not at all?) mentioned so far amid the Fairphone 6 battery discussion: Obviously the FP6 battery will be nearly impossible to charge externally – given its press connector. I added this in the first post.
Sorry, I discovered your question just now. The lid of my C2+ can be opened up to 57mm, the pins can move a little less wide. Wattgeizer does not any more have the other loader in the shop, and without having a look at the details, I do not recall what made me assume it’s an improved successor.
Coincidentally, I bought this very same charger in the hope of using it for my FP5, and never tested it because I always have dozens of things going at the same time. I also recently found a good auction on a new battery, so I have a second one in my hands. I hope I can find the time to test it, my main concerns with its design are:
  1. Being able to securely hold the large battery in place, the clip can help but given where the connectors are I’m afraid it’s going to clasp it at the end only
  2. The connectors being thin enough to actually get inside the contacts’ space.
