So my phone’s 3G is always disabled.
But sometimes I need to activate it. And it also activates itself when I receive a MMS.
My problem is that when I turn it off, for some reason, I can’t turn it on again. I need to go to plane mode, and then hopefully it works again.
I am aware there may be just a few of us disabling 3G by default, but it is a pain not to being able to use the 3G switch as expected.
I hope I was clear.
Thanks in advance
Are you talking about 3G (UMTS in Germany) in general, or data connectivity? I guess the former, right?
A possible workaround could be using GravityBox (from the XPosed Framework), go to Statusbar tweaks
, select QuickSettings management
, then choose to show “Network mode” under Statusbar QuickSetting tiles
. When you go to the Quick settings now by opening the notification drawer (downswipe) and the do a sideswipe, you should see which network mode you are running at a glance, and can change it by a tap.
Would that help?
