I have an issue with my Fairphone2, I wasn’t able to solve. I got a second SIM 2 weeks ago, and I had some troubles with Mobile data connection. I need to use SIM 2 data connection while maintaining SIM 1 enabled but I noticed that when I disable SIM 1, SIM 2 connection works properly (3g connection gets available and I can use internet); instead, when I enable SIM 1 again data connection stuck into Edge and can hardly ever use it.
At the moment my configuration is the following:
Sim 1 -> enabled -> preferred network type: 2G
Sim 2 -> enabled -> preferred network type: 4G
Preferred SIM
Mobile data: sim 2
In Data usage section I also disabled Mobile data for SIM 1, and I left it enabled for SIM 2.
Is something wrong with my config?
I would be grateful for any help and advice!
Thanks,
Jamila
Hello @Lidwien,
thanks a lot for your reply! I checked options on Sim 1 card, and all I can choose is 2G or 3G or 4G. For this reason, I thought to configure Sim 1 as 2G and Sim 2 (that I want to use for Mobile data connection) as 4G.
Could you suggest me something different I have to do?
Thanks a lot,
Jamila
Have you already tried switching the cards?
Otherwise your settings seem correct, especially since it’s working when you use the second SIM only.
Or maybe it’s a problem caused by the first SIM?
You could ask your operator for a new one (an exchange might be for free even); possibly there’s a new version available. Your operator should at least be able to tell you, if the SIM might be causing problems when being used in a 2 SIM environment.
An internet-search could be helpful in this case as well, as you surely would not be the first one to run into trouble. Try searching for the SIM-card version number that is printed on top of the card together with the provider.
All of this is just wild guessing unfortunately.
@BertG thanks to you too for the advice, I’ve been searching a lot on the net during these days about this problem but I didn’t find anything useful to solve it. No, I didn’t switch the cards yet, I will try! If I won’t solve I’ll try to ask SIM1 operator too.
Hello guys,
Thanks to your advice it seems I can now use my new Sim data connection properly! First I tried switching back and forth SIM2 setting to 2G and back to 4G (I rebooted my phone too after each setting change), but that didn’t solve. Than I swapped the SIMs, and that worked perfectly! I will ask my older SIM operator to provide me a new one too, I think that is a good thing anyway. You all have been really precious, I’m going to check the topic as solved.
Have a great evening,
Jamila
