/e/OS 0.12-2020102981459 - fp3 not booting after update
Hello guys,
surely it’s been answered yet but I haven’t found it so im asking again.
After I’ve installed an /e/-update on my fp3 it didn’t boot. It says “Can’t load Android system. You continue to get this message, factory data reset and erase a device.”
Is there any way to save my data before I factory reset it (with the recovery or maybe even Realterm)? I’ve still access to the recovery.
I’m very thankful for any answer in advance :slight_smile:
Thanks a lot and have a nice evening,
Chris
Did you try to boot from the other slot yet?
Edit: have a look e.g. here:
Due to problems earlier the update to 0.12-2020102981459 was blocked to prevent more users getting into problems.
Today the blocking is lifted.
So it is possible to update to 0.12-2020102981459 and it went smoothly on my phone.
This update doesn’t included the update of microG which isn’t expected before the second half of november.
Wow, thanks a lot for answering my questions. Great that you are spending your time to help me with the phone.
Best regards
Chris
Dear Volker, Dear Another Elk, Thanks a lot I tried it and it WORKED :smiley:
It saved me a lot of data and time, too - what a nice thing to have the device as it was
Thank you for your advice and help
Yours
Chris
That’s marvellous! Thanks for the feedback!
