you can use Signal to send and receive SMS too. You can later choose if you want to exchange data messages with a specific contact rather than SMS. Unfortunately you cannot choose per message. Install other messengers using SMS like QKSMS in case and choose them as default at first run. There are messengers in F-Droid for encrypted SMS as well.
The OS itself is stable… just some new things are not fully polished, yet.
Like the launcher asked to turn on location on every reboot (for the weather widget), the file synchronization shows a message on every upload (debug), files get uploaded twice, file sync eats up data … I didn’t use the sync since the very beginnning, so maybe some stuff is fixed already…
Those things are work in progress.
Put the .img into the directory on the PC where you have fastboot installed (resp. where you start the command).
Put the.zip (according to step 8.) on the root of /sdcard (on the phone).
You might also ask any /e/ specific question in the /e/ user forum.
Hi @Volker,
So, what do you think after 2 months? Are you satisfied? Is /e/ an OS that could be installed on a phone for someone with few skills (one’s parents for example…)?
For me /e/ really works fine and very stable! So I’m satisfied and I’m planning to stay with it.
Honestly for someone with few skills (one’s parents for example…) I wouldn’t currently recommend it as
It’s still a beta and I wouldn’t recommend beta versions for less skilled people
It’s (currently) based on nightly updates and I suppose less skilled people won’t like the frequent updates
Afaik it’s still not clear if there will be an automatic update to 0.2 once it’s available for FP2. So the update may be challenging.
Correct me if I’m wrong, but /e/ 0.1 is based on lineageOS 14 and so has the same problems.
To, answer the question: yes, the flashlight has to be turned on for shutdown and for update (for being sure twrp is started correctly).
The /e/ community were the ones who reported this workaround … before that for us it was powering down from TWRP or from the decryption password prompt, or removing the battery …
Once version 1.0 is here it might really be interesting for “one’s parents for example”. Among other reasons one may be that it’s supposed to come with an integrated app store providing lots of common apps (of course without the need for Google play):
That would be great if they really have a lot of apps and if you don’t have to download special apps with another store. I can imagine that it will be difficult to have all the national/regional apps: on the link you sent, some people ask for example for apps for their local public transport.
I look forward to seeing version 1.0!
Hi
I’ve tested /e/ a bit and the new update messed things up again, and I think I want to switch back to LOS+microG
Should it be easy as in wiping the system and installing LOS+microG?
Should be the same as coming from LOS14.1 upgrading to LOS 15.1, right?
Normally a clean flash would be the savest way of course, but would be nice if the app data etc. will be preserved.
Opinions?
Thanks and cheers!
