Oh dear. I dropped my fairphone 1 yesterday on the ground ( it was turned off).
When I tried to turn it back on the on/off button wouldn’t depress properly and all that happens is that the screen lights up for 20 seconds then goes black then lights up again - I’ve plugged it in overnight and its continued to do that so I cant turn it completely off either.
I also tried holding down the volume button for a long time and after a while the android robot appeared with a ‘no command’ tag.
There are no sounds and when I ring it it doesn’t react - is it likely I could fix this?
Thanks
Sounds like this:
