There is no french version for this topic.
You can create one if needed, else the topic creator defines the language of a topic.
I translated it into English. But still stuck with my photos just on my phone
Sorry too much of a novice. How do you run dmesg from terminal? If possible, step by step please
Since you are having difficulty downloading from the Fairphone, consider downloading the photos from Google instead. Then once you have confirmed they are on your Mint computer you can delete them from Google to free up space.
Hello, I use CX File Explorer on my FP, openssh on my Linux PC and filetransfer via sftp in both directions.
Works fone for me, Karl
I ran my own Nextcloud server on my Linux PC and use the Nextcloud app to synchronize photos, calendars and contacts between PC and our two Fairphones - works very well for us.
Try your phone with a different computer and/or a different phone with your computer.
Then you should know whether the problem is on your phone or your computer.
connet the phone
open a terminal
type:
sudo dmesg
paste here the last lines
Do you see this in Nemo (filemanager in Linux Mint)? That means that the usb settings on the phone are likely incorrect. You can change this on your phone in settings-connected devices-usb. If you can not find the usb setting in your phone, you can search for these directly in the settigs menu (search for “usb”).. There should be the option to set to phone to transfer files via usb. After that: Nemo shows possibly an annoying MTP error. You can ignore these messages. These MTP errors are caused by Android and not by Linux Mint.
FP4 and Linux Mint here. Transfer works, although when I connect the phone the computer sometimes doesn’t recognize it (resulting in various error messages, including the one you quote). In this case unplugging and re-plugging again helps. Also, don’t have Nemo running when you connect the phone helps too.
Some things to check (in this order):
- Did you try using another cable?
- When you connect the USB cable, swipe down and check if you have a notification saying “USB File transfer turned on”. Click on it to open “USB Preferences”. There are two settings there, they should read “USB controlled by: This device”, and “Use USB for: File transfer”.
- Try to connect the phone with that same cable to another computer (whatever OS). If this works, there is maybe a problem with USB on your Linux computer.
Pour le cas que vous avez un problème avec l’anglais, voici en version française:
J’utilise un FP4 et Linux Mint moi-même. Le transfer fonctionne, quoique parfois quand je connecte mon téléphone il n’est pas reconnu, me donnant divers messages d’erreur (dont celui que vous citez). Dans ce cas il suffit de débrancher et rebrancher le cable. Il est aussi mieux de ne pas avoir Nemo ouvert quand vous connectez le téléphone.
Quelques chose à vérifier (dans cet ordre):
- Avez-vous essayé un autre cable?
- Quand vous connectez le cable, balayez sur votre téléphone vers le bas pour voir les notifications et vérifiez que vous avez bien la notification “Transfer de fichiers via USB activé”. Cliquez dessus pour ouvrir le menu “Preferences USB”. Vérifiez que les paramètres sont bien “USB contrôlé par: Cet appareil” et “Utiliser USB pour: Transfert de fichiers”.
- Essayez de connecter le téléphone avec ce même cable à un autre ordinateur (peu importe le système). Si ceci marche, il se pourrait qu’il y a un problème USB sur votre ordinateur Linux.
I am going ape mad. I have donleaoded to Google Drive. But the format is under AKD and I cannot open them.
Thank you. When on USB settings, my phone doesn’t allow any change. How does one unlock that?
For me using the app “KDE Connect” is a good way to transfer data between smartphone and computer. It’s available for Android and computer operating systems. I use it with my FP6 and my Arch Linux system and can recommend it warmly.
There even are versions for Windows and IOS (and more).
Regards Stephan
First check if you have the installed the latest updates on the phone and if the usb ports and the usb cable work fine. If there are no problems with the usb ports on the phone. on the computer or with the usb cable you can use USB debugging in developer mode on the phone. First connect the phone with the computer. After that you have top enable developer settings. This can be done by settings-about phone-build number. You have to tap seven times on the build number to enable the developer settings. After that: settings-system-developer options. There you can find the ‘usb debugging’ option that has to be enabled (and press ok to confirm). After this you can expect a message on you computer that asks you to allow ADB on your computer. You have to allow this. After this Nemo should have no problem accessing the phone via usb.
I’m also using Mint LMDE and the file transfer works perfectly, just as patrick4 says.
If the problem persists, you can also use KDEConnect, which you’ll find in the software centre. The app is very easy to set up and the transfer is almost instantaneous ![]()
