Does anyone know what the Timeout function does?
Hi! I don’t have a problem, I’m just curious to what this function does. It appears when you click the top right corner in the pull down menu (where you can controll wi-fi etc), and you can make it on a higher or lower “level”. I just don’t know what it is that I’m making higher or lower… So as the topic says, what is this function?
It’s the display timeout.
Hi @JohannsanP,
this function controls how long your display light is on when you’re not touching your display.
Low -> It turns off on itself rather fast.
High -> It stays lit for a longer while before turning itself off.
I’m not sure you can set specific times, I’m guessing this ranges from around 15s (low) to probably a minute (high).
Go to System Settings > Display > Sleep. You can set it (in steps) between 15 seconds and 30 minutes.
1 bar: 15 sec
2 bars: 30 sec
3 bars: 1 min
It would be nice if these settings could be customised.
