is there a way to disable the camera switch at the side of the FP2, because my smartphone holder in the car always presses this switch.
Thanks
Wolfgang
I never tried it but maybe if you go to Settings > Apps and disable the App “Programmable Button”.
By the way, how can you actually “program” this button to start a specific activity?
Thanks for your answer, but I have no App “Programmable Button” in “Einstellungen” - “Apps” or is this anywhere else ?
You can find it if you switch on display of system processes in the 3-dot menu.
Thanks,
but I tried it now, but the button works at all …
If you have a slim cover you can try simply removing the button. But then dirt might enter more easily.
How about sticking some tape over the hole?
I abraded the button with my “Dremel” - tool. So there’s no hole, and the button does no longer work.
So my problem is solved now.
