Hi
I was in a region where the mobile provider supports only GPRS or sometimes EDGE. I really know that data connection with GPRS or EGDE is very very slow (but it’s enough for small text only emails). Now I had the problem that FP1 didn’t try to setup data connection. As workaround I found out to disable “3G-Service” in settings - mobile network settings. Then I re-enabled “3G-Service” again and the data connection was established.
Hi @Martin this sounds like it may be that the network simply isn’t picking up the required information from the network in a timely fashion. I don’t think is a bug as such, it’s simply how phones operate. Turning data off an on just forces the phone to try and establish a connection.
I have moved this topic into the Fairphone Help! category so that others will see this and may be able to offer further help or tips.
I get a similar problem even in areas of good 3G/H/H+ signal whereby I leave the wifi, and it won’t hop on to the mobile network. I can’t reproduce the problem with the native operator, and it seems to only occur with the MVNO operator who piggyback on another operator. I haven’t tried any operators yet, however both myself and my wife have the problem.
