Crackling sounds when playing Inventioneers
I recently installed a good old game called Inventioneers, a kind of remake of the even older Incredible Machines.
On FP6 running the latest software (Aug 2026 update) the music of the game has crackling sounds, which is a bit unexpected because it’s an old game that shouldn’t use much resources.
The game used to work fine on an old iPad and a newer Chromebook.
My display is set to 60hz and the game is the only active App.
I’m running out of ideas to fix this.
The issue is easy to reproduce, just start the free version of the game and listen.
Thanks for any suggestion,
XB
