Constant screen brightness jumps on A13
I did the Android 13 update a few hours ago on my Fairphone 3 and it generally seems to work fine, except the auto screen brightness.
I have screen brightness set to 0 and I’m in a dark room, but the brightness will jump up to somewhere between 30 and 70 percent for about 2 seconds at least once every two minutes.
I’m in a dark room and this even happens when I’m not touching the phone and with the sensors covered.
Hi crystal,
Android 13! Have they skipped 12 then?
Yes they have
No such problem. As a Beta tester I’ve been using the A13 for some months.
You may try a restart.
Check if you have an SD formatted as internal and check your memory status is above 6BG
You can also run in safe mode for a while to see if it still happens
I wonder if Android is not trying to learn which brightness you “like”.
Do you also have this problem if you deactivate the automatic brightness ?
Had this problem in the beginning, too. But everytime when the brightness jumps without any reason, I manually set it back.
After two days the adaptive brightness logic learned about it, obviously, and the problem was gone.
I got the same feeling here!
