Connecting with the pc doesnt work, only loading
connecting with the pc doesnt work, only loading
Verbinden mit dem PC nicht funktioniert, nur Laden
Did you make sure your cable is a (4 threaded) data cable and not just for charging?
Anyways you should try as many different cables as you can get a hold of.
This link might also help:
I have the same problem, none of my available cables (1) works properply. Im thinking of buying the cable from Fairphone, but they only sell a cable labeled unter ‘FP1’ Does anybody know if this cable is compatible with the FP2?
Thank you for your answers. The problem is the cable. I have check all my cables an one of four works. So i think there are different cables!
C.U
