When I reboot my Fairphone4, connecting my bluetooth-headset is basically instantly when I switch it on.
However, after a fed days it begins to take longer and longer time. It just grows and when it takes 30 seconds or more I have to reboot the phone, and it is back to connecting instantly again.
This happens every time, and has been so since I got the phone i February and remained after the latest system update.
I assume that you’re on the standard FP OS and not some custom ROM? Did you install the recent upates?
I’m using a bluetooth headset with my FP4 all the time, plus occasionally some other audio devices and cannot confirm this problem.
Do you have any other bluetooth devices to cross-check this with?
Hello!
I have the same issue of tsvenson.
Indeed, I pair both Google Pixel Buds and Amazon Buds 2 with my Fp4 and happen the same problem. Often those headsets need more than 20 seconds to connect whit. It happens also with my Fossil Gen 6 smartwatch than notify on late than the notification received on the smartphone.
Hi OldRoutard,
I tried everything you wrote and nothing resolve my bluethoot connections problem with both headsets. I don’t know what I can do to resolve it. Can it envolved with the 5G issue? On my device, if the “5G/4G/3G/2G” taggle si activated, often and randomly Fp4 restart itself.
All the last update are installed on my device and I dont use battery saving options.
I hope in some solutions because I love my Fp4 and all the philosophy around it but I use it for my work and are very important for me the true-wireless headsets and the 5G connection.
