I can´t connect to my isolated company wifi. It connects and after 2sec. it disconnect, then it reconnect and disconnect and so on and so on.
How can I connect to a internet less wifi?
There must be a way, because not every wifi network has an internet connection, especially in professional settings.
On the first attempt when trying to connect your phone should ask you if you want to connect even when there’s no internet. You may try to “forget” (and reconnect) the WiFi network to retrigger that dialogue.
You might also try to disable mobile internet (data/internet through mobile provider) while trying to connect.
