I can confirm this. I don’t have inserted a SIM-Card yet (and didn’t establish a Wi-Fi connection) and this might be related to the issue (as the description of the below mentioned setting says: “Use network-provided time”). However, even if I set
Settings --> Date & time --> Automatic date & time Off
and manually set date and time, it gets reset after reboot, which indeed is confusing.
It’d be nice if someone with the Stock-ROM could try whether it’s the same there after setting up the phone without Wi-Fi connection and without SIM.
I face the same problem. If a SIM card and/or WLAN connection is available, the clock gets updated after some time.
What I heard from others this problem doesn’t exist with stock firmware.
1|root@FP2:/data/data # dmesg | grep rtc
<6>[ 4.654128] using rtc device, qpnp_rtc, for alarms
<6>[ 4.657736] qcom,qpnp-rtc qpnp-rtc-f615c800: rtc core: registered qpnp_rtc as rtc0
<6>[ 6.247180] qcom,qpnp-rtc qpnp-rtc-f615c800: setting system clock to 1970-01-28 01:27:12 UTC (2338032)
<6>[ 15.457939] alarm_set_rtc: Failed to set RTC, time will be lost on reboot
<6>[ 61.216623] alarm_set_rtc: Failed to set RTC, time will be lost on reboot
