Can anyone tell me whether Cleaner Tool Box is a scam? Should it be on my phone or should I disable it please?
That’s for sure no standard app delivered with Fairphone OS. So did you install it from the PlayStore or a third party App Store?
I’m not sure which. I got scammed and thought this was the interior app trying to clean it up but I think it was part of the scam! I tried to deinstall it but it is still on my phone.
make a factory reset, if its still there, it might also come from your network provider.
But i don’t want to lose all my photos and audio files. Would my sd card be affected by a scam? I thought about saving them onto an old computer which doesn’t have internet connection but I don’t know if that is possible.
Thanks everyone! Much appreciated. I will let you know how I get on in the next few days.
