Over the past few days I had a problem with my FP2 not holding charge, taking a long time to charge, and it got worse and worse.
Now, it won’t charge at all. The red charging light is very faded. It blinks, but you can only see the light if the room is dark now. I feel its either the battery has died, or the charging port is broken.
Any advice?
Also I am in India, is it easy to get parts sent over here?
To me it sounds like a problem with the bottom module (resp. as you said, charging port is broken). Anyway you may a have a look at #batteryguide.
I’m not sure who sends replacement parts to India. You may look for resellers and check them here.
