Is it bad for the battery if I use a travel charger with 1,55 A output?
Short answer: No.
Long answer: It is probably worse for the battery than using a charger with only 0.5 A output since slower charging is always better for a battery. But since the phone itself allows up to 1 A charging current and limits this even if the charger is able to provide more (which is the case with your charger) it won’t do any unexpected harm to the battery.
Thanks! Very helpful!
