First week using my fairphone2 the display glass is already broken… It fell flat on a rock. But the display it self and the touch still work perfectly. Is there a way to change the glass only ? I don’t want to throw away something that works fine.
Als far as I know that’s not possible, it’s glued to the display unit. But maybe you could stick a protective (glass) foil on it, so the cracks won’t get bigger and you don’t cut yourself.
