Hey there, i’d like to make a change from FP1 to FP2. Any suggestions how to Save contact Information and make it to the FP2? I guess there’s no Problem with the SD Card. For all the Apps i will Do it over Google Play. Also no Problem with that. Only contract Data. Thanks in Advance. Uwe
MyPhoneExplorer may help here.
You may have a look at
You can use your contacts app to export all contacts to sd card. It will write them to a single file, which you can import into the contacts app of your FP2
Doesn’t Google store the contacts in the cloud anyway?
Since you use Google anyway I think you can just log in to your FP2 with your Google Account and enable sync (or something like that).
