Change to iodé, now problems with mobile network connection
recently I gave up /e/ on my FP3+ and changed to iodé: more save, better programmed, more frequent actualisations.
Most things work. But I have two SIM cards. SIM1 I use only abroad, SIM2 is my local network, which works fine. From time to time I would need SIM1 as well (spanish SIM from Digi Mobil). AfaIk, both SIMs use mainly the networks from Telefonica. But I got the following problem:
  • The automatic network connection for SIM1 does work only very rarely. Most time there is no connection, from time to time I see, that the connection symbol is full/activ. So I tried to select network manually (switch off “automatic network selection”), but then I get the message “networks not found” - without any search! This is strange, but the same for SIM1 and SIM2. Prefered net type is LTE.
Any idea about another thing to check? (I did several restarts…)
Best
Peace
Was this working fine before with /e/OS, or did the use case just emerge after going to iodéOS?
Android offers a network reset in the settings which really can help with odd network behaviour, but it will also affect WiFi (passwords) and Bluetooth (known devices to connect to).
Thank you!
It was fine before with /e/, so it is a new behaviour. Strange for me, that sometimes connection is displayed. I didn’t manage so far, to try if in these short time slots real connection is possible.
Interessting might be: /e/ is still on Android 14, iodé comes like LOS with Android 15.
Interessting: Where can I find this?
Thanks again.
I found it: System - Options to reset. There I can select, what kind of connection and which SIM I want to reset. Directly this doesn’t help, I check it.
It still doesn’t work, not even after restart.
Another symptom are, that the network symbols (for both SIMs) in the status bar on the right side are limited by an exclamation mark. I had to look again to realize that.
Further the indication in SIM card settings for SIM 1 is “emergency calls only”, but I didn’t try this.
Meanwhile I have seen, that when SIM 1 network symbol shows a connection this “emergency call only” remains and a connection cannot be established.
So any idea how to get back network selection possibility?
Edit: further observations…
