Hi!
Can I adjust the speaker phone volume? it is way to loud.
Hi!
Hi
The volume buttons should work when you are using the phone. You can also go to Settings > Sound and adjust various outputs
Ah thanks. Tried that but it is too loud in the minimum setting.
I have the same problem, the call volume never reaches zero.
Even when the slider is at zero the volume is still loud.
Ciao,
Max
What are you using the speaker for in the case you have that is too loud? Mine goes down to nothing with media , yes but not so quiet on the loudspeaker on calls.
Same problem here - the minimum speaker call volume is very loud. The volume rocker does change the volume, to make it even louder.
