I am trying to install a new certificate on Fairphone 1. But it does not seem to work…
Any help ?
- What have you tried so far?
- Which specific certificate are you trying to install?
- Is there an error message?
The certificate is 79neufcom.crt
I have installed it (the fairphone message has confirmed it), but I cannot see in the certificate list.
WhenI try to subscribe to a podcast that use this certificate the following ::
Could not subscribe.
java.security.cert.CertPathValidatorException. Thrust anchor for certification path not found.
I use the Podkicker Pro android application, but the same message appears with other application.
