2 posts were merged into an existing topic: 15.1: Boot to Recovery
So, Iāve adjusted it, feel free to check it out.
Looking good .
And now a vertical flip case please.
Bonus points for space left out at the bottom around the micro USB port for charging with the case closed (space large enough for micro USB connectors and magnetic adapters).
Thatās why I made a booktype flip case but I will keep it in mind!
Do you recon it is going to fit inside a Feuerwear Mitch 10? Thatās my current case (without the option of holding my OV Chipkaart), and I like using it together with a belt so the phone doesnāt fall out of my pocket (yeah, that already happened and I was lucky the finder was honest).
On Amazon you can find a variety of holders, holsters, hard and soft cases for the Fairphone. When they advertise it as āfor Fairphone 2ā they have to deliver correct dimensions.
Also, screen protective foils are available. I bought one, but since then havenāt used it (FP2 comes with one, but thatās just a scratch protector, but it fits so snuggly I did not want to remove it so far).
At the moment I use this soft case (felt):
and this holster (leather):
I try to use things that are at least similar to the Fairphone spirit, so I would prefer European materials and manufacture, natural stuff if available. The felt case I use daily. Its kind of thick, but that also means it is protective. High quality. The leather holster is also of quality, but for my liking the belt clamp is a little too strong for anything but the thinnest belts, so putting it on or off is not as easy as it could be (but once attached, the holster is FIRMLY attached to the beltā¦).
So far I bought, but have not yet used this protective foil:
Veeeery nice.
Thanks for listening. I think the visible color rim from the case around the camera (no matter which case color) somehow to me looks like extra eye candy. I hope they sell well.
Hm, just another ideaā¦for some phones I have seen cases to fold up as a stand. Do you think there would be a demand for such cases (H/V keeping the charge option available as an extra ) for the FP2?
I think itās a little bit to big for that feuerwear caseā¦
