Can't hear calls
Recently when I’ve made and received calls I can’t hear the people on the other end, but they can hear me, even if I turn off the Bluetooth. I can only hear them through my hearing aid (Phonak) that also has Bluetooth and on loudspeakers and I can’t use them all the time. How to search for solution?
hello
as you mentioned Phonak, perhaps this topic would be helpful?
Please let me know if that is relevant and then I will merge your post with the others.
As I can hear with my earpods the solution isn’t there. I can’t hear anything without bluetooth or speakers. I made a GMT test and it says bothh Speakbox Top Speaker and Bottom Speaker failed. What does it means on HALL that I need to flip cover? What is NFC and HAC? Because they fail.
So no-one can help me with this issue?
You better contact support
