Hello.
I have a problem with my FP3, i can’t flash anything, if i try to flash the stock OS it says “The critical partitions are not unlocked.”, but if i unlock it, and try again, it says the same error…
If i try to flash the files manually or flash another ROM, it shows the partitions as “NULL_VENDOR” (This is an example, but it does this with every rom, even stock OS)
I can’t boot into recovery and Android (Obviously), and i don’t have Bootloader and Baseband versions anymore, what should i do?
