when I start the Fairphone 3 there is a message on the locked screen in German “Der Speicherplatz wird knapp” Einige Systemfunktionen funktionieren eventuell nicht." in English that would be the storage is full, something might not work. If I enter the correct pin the screen gets black for a one-second then there is the lock screen again. If a wrong pin get entered, there is instant feedback that this was the wrong pin.
If I start the recovery mode, I see the Android logo with a red error sing and “No command”.
I tried briefly holding the power button and briefly pressing the volume up button like suggested in the forum [ "No command" message ] but it did not change anything.
It is possible to start fast boot but since the device stat is locked I do not know any commands that would work. Are there any, since I know the pin of the device?
Is there a way to factory reset the device? Or to clear the storage?
The data on the phone is not that imported, but it would be good to be able to use it again.
I removed the picture as it contained serial number etc.
Reg recovery: did you try several times to get past the robot, its a bit tricky. However from the bootloader (your picture) you can start into recovery as well, does this also brin you to the no command window?
