Hi
I cannot send and receive MMS unless recipient is set up for RCS. I have spoken to my telecommunications company several times and have received help setting up the APN, it works now (only) when the one I send or receive from is set up for RCS. Its a new Fairphone, I had no problems with my old android phone (it was not a Fairphone.
Can anyone help??
just brainstorming here.
are you using two SIMcards or one?
Hy,
in Germany we dont have a MMS system without RCS. The Standard MMS is not longer available. Perhaps it is the same in your country.
And the follow up question, are using Google messages?
Hi thanks for your thoughts- I have one sim card - and yes Im using Google.
Thanks for your thoughts - I live in Denmark, it’s probably on its way, but many people still use the old system..
Hi, thanks
I can only send mmms when my SIM card has primary data preference even when on WiFi I believe, that’s why I asked.
I notice that RCS settings are seemingly only managed through the Google account.
You might want to turn off RCS if you’re encountering problems.
There is also a setting ‘Automatically resend as a text’ which I presume is designed to provide a solution for the problem you describe.
