I can’t use my camera. I tried with Kola Nut 1.8.7 and Cherry 1.6 and Jelly Bean. And retour.
I tried the standard camera and the open camera.
I also tried the hard reset.
Nothing brought a solution.
Mostly I got the Error: Can’t connect to the camera
Or the green screen.
the first months it worked well.
then it began to get the “Can’t connect to the camera”-error once a month.
Actually, I didn’t have the standard camera app, also a new installation didn’t brought it back.
the open camera app did work after the new installation for two photos.
now I get always the connection-error.
It is important to choose the right zip file. Which one matches depends on your storage. Do you see 13GB internal storage when looking at “Storage” in the settings?
If you have tried both, this looks like a hardware issue. Go to Testing Mode and do a camera test. If the camera works in Testing Mode, then your problem is caused by software. If it doesn’t even work in testing mode, then you have a hardware failure and need to arrange a repair (possibly on warranty, if you did not do any physical damage to your phone).
