carot
August 1, 2021, 10:51am
#1
Hi! I drowned my phone (fp2), and at least the battery is broken. I would like to try if the phone still works. Therefore my question;
Can I lend a battery from someone to test the phone before I order a new battery?
Would be great!
Thanks, Carola
Define “near Rotterdam”.
There are several #fairphoneangels in the Netherlands, for instance, you can locate and contact them via the #communitymap .
carot
August 2, 2021, 7:20am
#3
Hi, more specific it is Bergschenhoek. Thanks for the tip about the communitymap. Will give it a try
I rather meant … How far away from Rotterdam would still be near enough for you to perhaps go there ?
system
closed
January 29, 2022, 7:29am
#5
