I would like to know some specs of the camera (2nd gen). Namely:
- focal length
- sensor size
- crop factor
- horizontal field of view
All I can provide at first glance is from the main Fairphone HP tech specs:
You may find even more information directly at the Omnivision manufacturer HP.
Thanks. What do you mean by HP?
I’d guess … Home page?
I really wonder, if information like focal length and field of view are available for that kind of camera? I am a bit sceptic to be honest.
Obviously the Omnivision homepage will not provide any information on this behalf, as this is is destined by the optics/lens and not the sensor.
Focal length may be included in image EXIF data - I don’t have an FP2 so I can’t check. On the phones I can check, where I can show EXIF data it seems to be included.
You’re right the focal length is indicated. However the other data I’m looking for is not.
